high comp 2l b18c block motor with no power
OK so i built a high comp b18c that is bored out to a 2 litre this is the specs
b18c sleeved and bored to 85mm
forged 85mm 12.5:1 comp cp pistons
carrilo rods
balanced crank etc
ported and polished ITR head
skunk 2 pro 3 cams
45mm ITBs
fluidampr race
moroso kickout sump
AEM adjustable cam gears
skunk 2 pro valve train
Apexi power fc comp
currently the motor has been run in and has been tuned by Race Solutions in penrith but is only pulling 128 kws and is taking upto 40 degrees ignition timing and doesnt ping even on standard pump fuel it has been compression tested and pulls from 245 psi to 195 psi through the cylinders...I just wanted some ideas of where to look at next cause Race solutions is out of ideas and im not wasting anymore money with them
Any ideas would be good thanks
