Da9 b16 donor into Ef
Hi all,
I have read the below article but wish to clarify a few more things.
Article:http://www.ozhonda.com/forum/showthr...ine-Swap-Guide
Donor car is a 1992 Da9 running a jap spec b16a
Things I wish to confirm:
- would i be able to use the mounts from the Da9 b16 into the Ef?
- would da9 or ek Gli rear disk brakes work with the Ef?
- is cutting a re-welding the shift linkage be reliable?
- anyone else tried this swap ?
- should i just keep the Da9 running or do the swap what do you guys advise me?
Thanks in advance
you guys are champions:wave:
we started it and gave up in the wiring department...
otherwise most of the mechanical parts are interchangeable and will work in the ef
I know its not much help, but I wish u all the best
u should document it if u go ahead and share it for others...
What happened with the wiring ? What made it too complicated?
If I use the wiring from the da9 would it make things bit easier?
that's the issue, we tried to do that exactly, but all the plugs etc didn't line up/match up
plus it doesn't help that the ed we had was carby originally :(
it can be done and it can work, just either lots of time to work out the wiring, or very expensive if u buy a loom etc from reputable companies who make plug and play stuff
