any know how to adjust the front headlight?
theyre aiming to high, i need to point it downwards alittle bit.
anyone?
anyone?
well i know all hondas have 2 screws each side, in a particular vechile, such as Honda jazz,
would u have any idea where are the leveler screw located?
just for ur curiosity.
let me explain since no one bother answering my question.
either you need a very long philips head screwdriver (MORE THAN 20CM long)
or a size 10 spanner.
theres 2 way you can do this.;
1. Do it from the top. there should be a writing next to the HEADLIGHT inside the egine bay. theres should be 2 arrows drawn, one states R-L and U-D. you can just slide the screwdriver to the specific hole and folow the arrow of direction.
2. Do it from under the guards, when u open the plastic guard. you can see clearly a 10mm size bolt stuck just behind the headlight housing. use the spanner and turn that to adjust UP n Down only. i find this faster than NO.1
n yeah, u cant adjust right n left from the bottom. so thats all.
