94/5 civic VTI EH9 - Changed Coil, Rotor, cap - Still issues
Hi Everyone,
I've been searching everywhere on here and although I have read many posts with similar issues, I haven't actually seen anyone post that they have fixed the problem.
About 2 weeks ago my car stalled whilst in idle. Then again whilst driving in
2nd gear.
With a little help from this forum and people with more knowledge than me, went over a few things to check where the problem is:
- Cleaned the Idle air control valve
- Cleaned the Fast idle thermo valve
- Cleaned out the throttle body
- Replaced the plugs
- Tested the spark leads (all within spec)
After all this, the car then wouldn't fire up. She would crank but not fire up. Last night did the following:
- Replaced coil, rotor and cap
She cranked over and fired up with a good idle, but she was missing and you could smell fuel.
Thinking it might be the timing, started to adjust it (with a timing light). She now cranks and fires up but doesn't last long before dying again, which is making doing the timing difficult.
My question is, after doing all this, is the timing really the issue? Could it be the fuel pump? or something else?
Please help!!!!
