Installing LED/SMD Strip on JAZZ GD + vid (Can do the same to other cars)
Aim: Install an SMD/LED strip in the driver and passenger foot area. It will act like the dome light. Dim down when u turn on the car (doors close), turn on when doors open or when the car is unlocked or when u take out the key when u turn off the car.
Required: SMD/LED strip. Tape. Cost $10 for 2 strips. Well worth it for the finished product.
http://www1.dealextreme.com/producti...sku_5282_1.jpg
Steps:
1. Locate the fuse box under the driver side steering wheel
http://img11.imageshack.us/img11/4396/p2310091035.jpg
2.Feed the wires of the SMD/LED Up through the side and feed the wires to the fuse box
http://img5.imageshack.us/img5/1764/p231009103701.jpg
3. Locate the plug for the dome light. It is the plug next the the big yellow one and has 2 wires going into it.
4. Grab the 2 wires that you fed to the fuse box and connect it to the back of the plug. You should have enought room to shove more wires in. And test the + and - ends of the cable or the led wont turn on.
http://img41.imageshack.us/img41/7932/p2310091036.jpg
5. Repeat for the passenger side.
6. Peal off the adhesive on the Strip and apply it on your car.
http://img203.imageshack.us/img203/8202/p2310091037.jpg
7. Finished and now you can test it.
Other comments
Videos below so you can see it in action.
JAZZ:
http://dc105.4shared.com/img/DBDOKZb3/V231009_1037.AVI
COROLLA:
http://dc261.4shared.com/img/Bp9Sy0w...6/MOV00044.3GP
