hi guys
my car is doing this weird thing where is wobbles in a low gear at high revs and also happens in low revs on high gears? most of the time on the motorway not so apparent on streets. any idea what my problem could be?
Cheers
hi guys
Cheers
I had the same problem with my car.. It wobbled and made noises..
My solution maybe is to check your engine mounts they might be loose which needs to be retightened..
Jase
Wheel balance?
ill have a go with the engine mounts thanks jace89.
i shall try the wheel balance but i have tried it before it when away for a bit but i realised it happened again once i drove on the m4 but ill give it a shot. cheers Chauster =)
nice car btw Chauster
How's the tread on your tyres? My dad's car had a bit of camber wear on the right front side, so we rotated it to the back, which solved our wobbly/shuddering problem.
Otherwise...rear wheel alignment maybe? My mate's rear's were once way out of wack so it looked like he was driving half sideways from behind, and when I took his car to like 160km/hr it was wobbling/swaying like shiiiiit lol
thanks lol.
Yeah as dougie said its most likely something with your wheel aligment and balancing.
might want to check tyre pressure and other simple stuff you could be missing.
bring it over khoa diagnose it for ya
well i have checked tire pressures and got the balanced check at the front wasnt off much. maybe i shoud check the rear. i will get a wheel aligment done soon cheers chaustar . i dont think i have camber wear not really noticeable if i do lol buh ill check when i get the wheel aligment done thanks dougie . Ill Swing by one day NA118
