Originally Posted by
SiReal
door trims shoujldnt be too hard. as a general/universal guide, there should be a couple of screws - one behind the door latch, and one in pocket cavity (the hole u use to open and close the door from the inside). once those screws are off, remove all those bits off the door trim (pocket + door latch unit)
you would probably have to remove a triangle plastic cover on the corner of the door trim (where tweeters are typically placed). just firmly pull it off.
And then firmly but softly pull the door trim off the door itself (it is secured by clips). lift the door trim up off over the door knob and there u have it.
thats a very general guide and applies for the 6th gen accord.
