hi guys,
a mate of mine has a crx del sol, and his vtec somtimes gets stuck on after 'hitting' vtec.. its a b16a..
just wondering if its happened to you before? or you know what needs to be fixed
hi guys,
so the b16, just keeps screaming ?
does it keep kicking in? lmzo
dun geddit
Solenoid stuffed?
car not warm enough?
not enough oil?
leaking solenoid?
I wish my vtec got stuck on :p
Solenoid staying stuck on.
Gunked up oil blocked the galleries so the oil cant return.
My bet too.
Cant be leaking, or low oil if it was then he'd have problems engaging VTEC.
But it seems his having problems disengaging it.
I dont see how this is a problem.
Probably intake pipe loose - slight crack near the throttle body andGives a LOUD vtec like noise. Check your intake pipe is firmly fastened !
when the revs are out of the vtec range, the car dosent run properly.. he has been told its the vtec staying on..
there is oil, everything is all good..
he is thinking of getting a vtec conroller and he is waiting for a skunk2 vtec solonoid he just purhased
Maybe your friend is running TODA VTEC Killer Cams?
