WRENCHIN' WITH TRAV - Front Strut Bar Install
Aim: To fit a Front Strut Tower Bar to my eg5 Hatch.
http://undergroundimports.com.au/gal...001/posin1.JPG
http://undergroundimports.com.au/gal...0001/posin.JPG
Time: 30mins or less.
Required:
- Strut Bar
- 10mm Allen Key
-14mm Combo Spanner
-17mm Combo Spanner
http://undergroundimports.com.au/gal...oolsneeded.jpg
Info:
The quickest and easiest way to improve the handling of ANY vehicle is to install an aftermarket strut bar, heres a quick guide to fitting one, allot easier than most people think.
Step 1:
Ok pop your bonnet and undo the 14mm strut top nuts. Do both left and right. Easy as.
http://undergroundimports.com.au/gal...mm%20bolts.JPG
Step 2:
Now with the nuts off, install the strut bar brackets and do up the 14mm bolts tight.
http://undergroundimports.com.au/gal...ighten14mm.JPG
Step 3:
Ok now ensure the bar is not done up tight and is still a lil but loose( i mean if you are fitting an adjustable bar)
http://undergroundimports.com.au/gal...01/fit_bar.JPG
Step 4:
Ok when install the drivers side u may notice that there isnt much room with the throttle cabble being mounted on the tower, dont fret, just need to bend it away till u have enough clearance, like so.
http://undergroundimports.com.au/gal...%20bracket.JPG
http://undergroundimports.com.au/gal.../clearance.JPG
