Hi everyone,
Last time i went to the get a wheel alignment, the rear toe adjuster is pretty much at the limit of adjusting, does this mean the one or some of the bushes in the car now need to be replaced? which ones do i need to do?
Thanks
Hi everyone,
Thanks
might be that your trailing arm bushes are worn out, but you would probally start to feel that in the rear end if they were, might be that your trailing arm is a little bent this happened to my brother when we did the rear disc conversion the new arm was bent.
i don't think its bent, this is probably the first time any of the bushes have been needing replacement. 200000kms is a long time. so trailing arm bushes are he ones repsonsible for the tow adjustment, that what i thought. thanks
is it worth changing any others?
your toe on the rear changes as you lower your car. so if you have no more adjustment toe in or toe out you may just need to lower/raise your car a bit or maybe even get adjustable toe arms if your really low.
Check your camber.
If your camber is out itll effect your toe.
the toe adjustment was at the limit when the car was about an inch higher than it is now, so i guess lowering has made it a little worse. :S
i have camber but its not much.
