Hi guys,
How much normally people pay for the labour cost to get thrust bearing changed on ek civic? while I'm getting this fixed, should I do clutch and input shaft bearing? how much extra am I looking at?
cheers
Hi guys,
cheers
fai dola
ISB input shaft bearing is inside the gearbox. if you taking the gearbox out, so change clutch, Thrust bearing, and pilot bearing, which they come with clutch kit. Also resurface your flywheel. I would do something else which not everybody would do, change engine main seal.
Cost for this job, I really do not know, I see mechanics only for road worthy.
I've got a quote from local mechanic between $800 to $1000 to do clutch kit (including thrust bearing, spigot bush, rear main, fluid) that supplied and fitted. if it input shaft bearing, this will be extra as he has to pulling the gearbox apart.
the reason I asked about this cause.. I'm looking at buying the ej8 with whining problem caused by the thrust bearing (according to the owner).
the owner described the noise only occurs when car slowing down, foot off gas and still in gear, which my mechanic didn't thing it's either thrust bearing nor input shaft bearing
can anyone help?
Cheers
800-1000$, How much would they charge for engine swap :|
Whirling is def input shaft bearing.
Go for a drive - warm it up - then open bonnet and slowly press clutch in and out and witness noise disappear and reappear.
Whirling is DEFINITELY the ISB (Input Shaft Bearing)
It's been happening to my 97 EK for a while now.
It happens whenever the clutch is disengaged, but whenever i engage the clutch, the sound disappears. (happens real bad on 1st, 2nd & 3rd gear with clutch disengaged)
I'll be getting around in changing my clutch this week, by one of the local mechanics.
I recommend you to do the same, all you need is a brand new clutch kit, which all included with all the goods. Clutch plate, pressure plate & throw-out bearing & also have your flywheel machined (resurfaced) as @hmetro24 has said.
