Hey has anyone got konis installed on stock springs, mines dc2 to be specific
i was wondering if the springs were to be installed on the lowest perch on the konis, how much would it lower the car? i've searched but i cant find anything on this
its something like 1 inch front & rear,maybe a little less on the back
i should add,thats if your getting koni yellows
by memory its 1.25 inches
for a more accurate idea, just put a ruler on the perches and measure the drop or raise.
i think for dc2:
Front set, there are three perches and the middle perche is the stock height.
Rear set, there is only two perche and the top one is the stock height
2 on front,top stock
3 on rear,middle stock
yeah they are koni yellows, thanks guys
I have koni yellow with oem spring on my civic.
On stock perch and still have a big gap on wheel.
I'm not dropping my ride anyway. On it's softest setting, it's firm enough (for me). I notice dive/squat has been reduced significantly compare to oem dampers.
a great mod... :thumbsup:
Would theses drop an ej8 to low if it already has king springs? been looking into this option to
yes.. you can go lower, like what crxer said.
Koni yellow has 2 perches on front damper and 3 at the back.
When you purchase them, koni use the top perch at the front and the middle perch at the back.
Have a read on:
http://www.ozhonda.com/forum/showthr...i+perch&page=2
http://www.ozhonda.com/forum/showthr...ght=koni+perch
