Hey guys ,
i tryd starting my car and it wont start it just cranks , ive checked all of the spark plugs and they all appear to be giving out a spark.
Ive reset the ECU, changed distributor, checked fuses and still no go.
Help anyone?
Thanks
Hey guys ,
Help anyone?
Thanks
What car?
Efi or carby?
If Efi, is the fuel pump priming?
does it continue to crank or does it stop after a second or so? Have u tried to charge your battery?
B18C2 .. the car just cranks when you try to start it.
give it abit of gas when turning on
does your fuel pump prime and your check engine light go out?
if not then it sounds like your main relay. the joints can get dry. theres a simple DIY trick to bring them back to life. Just some simple soldering.
