hi~ just want to know is the DC2R springs and shock on EG, is it upgrade?
and is DC2R springs more stiffer than stock EG spring?
and is it the same weight as EG spring and shock?
ofcoarse the stock sussy on an ITR will be better then EG lol ITR is a sports car
but is the itr spring and shock lower than eg spring and shock like 2-3cm?
i just want to low 2-3cm and more stiffer springs
Yes the ITR spring and shock should be about a 1" drop (at most) on a EG and far more stiffer :)
SO, ofcourse this is something you want to look into then.
listen.
ITR springs and shocks , will not lower your EG. They may be alittle lower than say vtir or gsi springs but are stiffer rates , so wont actually drop an lighter eg at all. It will remain standard height but be nice and firm.
actually ben, syd put ITR sussy in his eg and the height evened up and lowered slightly. it was visible to the eye.
it wasnt earth shattering lowering but it did lower, handled tighter and was a BFYB cheap as chips upgrade.
*waits for sydsyd to post in here*
installed the dc2r springs only on my eg sedan. car was slightly lowered about 1 cm (half an inch).
did on my car too - raised over stock height. Handled great tho.
We can all agree that the drop - if at all is tiny :)
dc2r sussy on my ef8 raised it
i will let you guys know after i install it~cheez
