hi,
just wanting opinion on which one i should get, as my current dc2r BMC is dying.
if i went with the wilwood compact BMC would the cusco brake stopper work with it?
thanks
hi,
thanks
stick to oem.
the compact is not a good idea as it does away with the brake booster, which will increase pedal effort ten fold.
not only that but its highly illegal in australia to not have a functioning brake booster. (unless for some reason its different in qld)
cheers and yea i think qld would literally rape ya for that. Considering that i got a defect for my car being too low (110mm)
how do you know when the master cylinder is dying
tbh i dont know cos my mechy told me when i did the 5stud convo, i assuming how soft it felt and how much effort to brake
get a rebuild kit from honda or source another used one. The rebuild kit cant be used if the bore on your BMC is already scored.
yea it was a whole complete 5stud convo set
As benjamin said
Have U need to changed prop valve too?
I did whole 5- whole 5 stud conversion too
U need to change prop valve for correct brake line pressure
yea i did the 40/40 prop valve change
