Hi all, i have an EG Sedan now as well as the LS.
anyways, the EG over heats but not like the other ones i seen when i done the search.
i took it to my mechanic and he fixed up the thermo switch because the fan wasnt cutting in. that was all sorted and he made me a bridging wire just incase. he said there was an awful amount of pressure in the system and checked the level, which was fine.
anyways what happens is, when i leave the engine to idle, its fine, but when i start driving, it creeps up, i pulled over, checked that the fan spins, it does, so i bridge it anyways to make sure that the fans on to see if it could be anything else.
drive off, turn air con on while driving at night when its cool, over heats. pull over, pop hood, fans spinning, turn air con off, idling and then cools down, put the heater on free flow, air con off and finish the rest of the drive home, the engine temp sits a little above halfway.
i asked my mechanic when i get home, he said it sounds like a failed thermostat. I asked him if there is soo much presuure in the cooling system, could it be the water pump? but he said unlikely, must be the thermostat.
alot of people here have stated theirs has crept up when stuck in traffic, mine creeps up when im driving. so my spirits are kinda dampened until i find out what it is!
