J's Racing Header
Hi Guys,
I've got my Greddy Ti-c exhaust, and am waiting for my PWJDM intake to arrive within the next couple of days. So, to complete my fair share of splurging, I'm looking for a decent header.
S2ki recommends the J's after the Hytech header - but I can't remember if I read somewhere if it was compatible with RHD's...
Anyways, I'd be pretty happy with the J's from a few Dyno graphs posted up on s2ki, so was wondering what your thoughts are - especially those who own one - and so this attach to the cat converter??
Thanks
J's header will fit RHD cars. J's is deisgned in Japan which are RHD. I know of two people who ran this header here.
It will attach to the cat converter, but you should run a test pipe or a hi flow cat for more gains, otherwise you're just defeating the purpose of an exhaust setup.
Sorry I should have been more clear - I thought I read that the Hytech wasn't compatible.
Was thinking bout TP & HFC's, but aren't they illegal?? Don't wanna invest little and get caught to pay massive $$$
Test pipes are illegal, HFC's arn't. I used to run a berk 70mm.
Did you find it any good? $ ? will that fit well with both ends from the header and exhaust?
Sorry for all the questions mate, just trying to get the whole picture before the purchase. Thanks for your help
Yes it will fit both ends. HFC's are 80% flow over the stock cat which is 40% flow. Definetly noticable at the top end of the rev range. about $300 from memory.
Would any HFC for the s2k fit my kinda setup then? (I'm assuming they are one standard length and the same flange brackets)
You will have two size thickness generally a 63mm and 70mm (id go 70mm), if its designed for the s2k then all of them should be the same length and same flange size.
Ahh ok, I know that was an obvious question, but I have no idea on the practical side of this yet. Thanks so much for your help mate.
Have run a tp for over 2-3 yrs now.
Yeah but your car's to fast to get caught anyway!
