Just wonder can an ABS Unit install on an non ABS EG??
just like put an DC2R ABS unit on an EG, will it work?
if yes, what parts would required?
cheez
cheez
I believe it is possible after I read a worklog of an EG in poland transplanting everything from a DC2R.
You would need:
ABS pump/reservoir
DC2R Proportional valve
ABS lines
Not sure about the electronics but probably need the extra fuses etc. related to the ABS.
you also need to add
- ABS ECU
- ABS WSS on every wheel
- ABS Fuse box and loom in engine bay
- ABS knuckls to mount WSS
- ABS modulator
- ABS loom in cabin and in engine bay
Honestly not worth the hassles.
late model eg6s came with abs and traction control as optional items
best to get a front cut that has it all to transplant
other that u will be wasting your time, patience , and money
for some thing not needed on a small car
