hey everyone ive got a 1996 honnda civic cxi manual, im having issues with my speedo ive changed the speedo sensor and cluster but still isnt working, can anyone help?
what issue have you got to start with?
speedo not working or not reading the speed right or reading too high or low to actual speed?
did you change final drive or gear ratio etc?
http://www.ozhonda.com/forum/showthr...cs-Code-17-VSS
EK1 VSS signal at the ECU is B2 blu/wht ( second connector, second pin in on top row from left )
I've also got a speedo issue in my eg civic, its reading too low to actual speed limit(I think 5kph under the limit). Have not change gear ratio and final drive and im running 195/50/R15 tyres.
I'ved already tried the gps and it shows that im 5kph under the speed limit and when I'm following someone, I tend to fall behind. Probably gona leave as it is for now until I do engine conversion.
