Who is running a greddy e-manage or something similar and what are the limits they can be taken to in the form of running aggressive cams, hicomp pistons, larger injectors and so on,
Thanks
Thanks
come on guys and girls, someone must be running one of these piggybacks.
Considering your running an EG your more than likely OBD1 get your self a Hondata s100 its $285 and much better than e-manage or any piggy back out there on the market. For more information check out www.hondata.com.au
will it run B18c with 11.3:1, 304deg cams, larger injectors?
Hondata will run any modifications that you plan for your engine, large injectors and high compression is a walk in the park for a Hondata based ECU. Call up your Perth Hondata dealers and talk to them, they are the best source for information and local support.
SouthWest Customs & Classics
www.southwestcustomsandclassics.com.au
Cnr Del Park Rd & Southwest Hwy
North Dandalup WA 6207
Phone (08) 9530 1757
Fax (08) 95930 1758
Contact - Dayvd Hooper & Marcus Crolla
