Need advice on how to get the horn button to work for an eg5
I believe it has something to do with the contact points but not sure wat the fix is, any advice welcome
I'd also like to see this DIY.
Need my horn to work :(
No one? I know there r heaps of eg's running around with aftermarket steering wheels
My old eg si sedan had a saas wheel and saas boss and it worked fine, decent looking wheel as well, kinda like the spoon/ momo style
i worked it out, writing up a diy now
here it is
http://www.ozhonda.com/forum/showthr...20#post2792920
the horn works when the switch is grounded and the circuit is closed. Does your boss kit have a slip ring on the back?
The horn button needs to be connected to the wire on the boss kit so when its pressed it closes the circuit (grounds the switch)
