EG disc conversion Fekk Accidental ABS
Bought teggy wreck for various reasons. noticed the car is an ABS model. fml
Im presuming it wont make much difference, i just wont run the ABS module, and use a prop valve to suit instead. im presuming the ABS signal cables just tell the ABS unit that the wheel has locked so that the abs unit can back off.
so i could just reuse the discs without the abs unit and use my brake lines with a suited prop valve.
everything should still bolt up and aline right?
the teggy ABS model doesnt have like the lines comout of the booster and master at different positions due to the abs yeh?
