HI Guys. As i am new to honda & never owned one befor, How much oil does your CU2 Euro 2.4 use in 5000 klms.? Mine uses half way down the dip stick using The recommended 5w30 Honda oil..:eek:
All engines burn some oil. Have you topped back up and noted how much you needed to add? I dont know what half a dipstick equates to in liters.
Some CU2's do.... burn oil.
I think its 1liter from the bottom hole to the top hole on the dipstick. Could be wrong, would double check.
read here;
http://www.ozhonda.com/forum/showthr...53#post3934653
only way to fix it is a mini engine rebuild. thicker oil probably made it worse with more pumping resistance
OK How much oil should the 2011 Euro use on average.????
I've been told up to 1 liter per 1000km.
Lol engine rebuild it is
Ok. Put Penrite 5w40 full synth- tenths in & now after 4,000 Kys doesn't use a drop. Very happy.
use 20w70
will fix ur issue
ask spmr
R u sure cb
Pls advise
