90' CRX Corner Lights
Hey guys, this may sound like a stupid question but here goes.
I bought some aftermarket cornerlights today and went to install them but im not quiet sure whether the original ones are only held on by the two side screws or not, or whether there is another bracket i cannot not see, can someone please help?
CRXXX
I had to modify mine as the aftermarket ones don't fit - but I've also got aftermarket headlights which kinda worked out ok.
the main bracket is at the wrong angle to be bolter to thesame spot where the originals are. You'll have to work out a way to attach them unfortunatelly.
if you got 90-91' headlights than 90-91 parkers fit
if you got 88-89 headlights than the 88-89 parkers fit
however, you can make 91 ones fit into the 88 ones if you have teh correct lil' clip from the 91 model
oops forgot too mention
88-89 are held on by 2 screws on hte outside
and 90-91 ishelt by 1 screw on the inside
dont think this applies to aftermarket lights tho.?
it does fit with teh aftermarket headlights and parkers i had
i've had a combinatoin of 5 different headlgihts + parkers :)
I have a 90'crx and its has 2 screws holding it in. should it just pull out once i have removed the two screws?
Thanks heaps
yes... unless its still screwed in from the top bracket... it should be.
Thanks, how would i access the top screw?
You should be able to get to it with the bonnet open... and a nice thin philips screw driver.
alright, i will go and have a look, an get back on here in 20mins, thanks alot for your help.
CRXXX
