Who here has upgraded there brake lines to braided lines
pros and cons of this mod
yes i have,
pros:
more accurate feel when braking because lines dont enlarge under braking pressue
cons:
illegal if you dont get them done at a proper place
I did on my dirt bike.
Pro's:
Takes away the spongy feeling. Your brakes might not feel spongy now, but wait till you go braided! Gives you better feeling.
Con's:
None.
cheers for the info guys I will be buying my kit soon then
If your bike is brand new, you might not notice that much of a difference.
OMG, i only registered to tell you all to check your facts before giving dodgy answers.
Firstly, braided lines will not give you any better braking performance, they will not feel crisper, smoother, anything better than a freshly bled rubber line setup. Better pads increase braking performance. Different master cylinders affect feel and response.
The difference is **drumroll**
Braided lines will not expand under repeated heavy braking under track-like conditions, meaning you will not experience brake fade. Brake fade is usually worse with worn pads, it is when the brakes heat up the brake fluid so much it expands the rubber brake lines and results in 'spongy' feel, it can get so bad that you hit a corner with only 50% braking power, which is very scary at 210kph at broadford race track (ask me how i know:eek:).
If you own any sort of bike you should check out CBR250.com, massive biker community with much more mechanically minded people like myself, ready to help on any bike model.
Scoots out:thumbsup:
Also you are better off buying them from US sites, even with the dodgy conversion rate, check motomummy.com, i got my galfer lines and pads there for AU$200 which is half that quoted at peter stevens.
My best advice is to learn to bleed your brakes yourself, check the cbr250.com maintenance forum for 3 different threads on how to do it.
good to see some guys heading over here to spread some good info !
BTW , like cars would it cheaper to replace old lines with brand new OEM items or braided items ? Personally id rather get new OEM
Well that depends on how much the stock lines cost, you could probably pick some up at a wreckers 2nd hand or off someone who has recently changed their lines.
I'd always go braided due to me needing them for track days...
i was under the impression braided lines would only have some benefit if any under track conditions. Similar to its applications on a car, for street driving/riding i doubt you can feel or tell the difference between a car/bike equipped with braided lines.
