Does anyone know the cost to supply and fit a new clutch master cylinder?
Mine's apparently rooted with no pressure at the pedal.
Just want to know what I'm up for.
Cheers.
Cheers.
check fluid. & bleed the clutch first maybe? cuz if theres air in the system theres will be no pressure at the pedal.
check any leaks too ...
Just to let you all CL9 owners know:
the old OEM part number for the clutch master cylinder is 46920-s7a-a03 which is the one that keeps failing.
Honda has replaced it with a superceded part number 46920-s7a-a04. Make sure you are getting this when buying from the dealer. it's about AUD$250.
Wont really trust buying those remanufactured ones from US as they are resleeved from the failed clutch master cylinder. It will still work but not for long. Seen enough complains from tsx forums.
Thanks for the replies. I've been getting quotes ranging from $350 to $400. Hope this helps for future reference.
That's like retail plus another cut-throat mark-up % on top of RRP. STEALERSHIP !!
Can you confirm the replacement master has rectified the knotty/creaking clutch pedal?
I also need to replace a centre armrest/tray lever. Found the part number (83419-SDA-A01 if anyone was wondering).. do I just go to a honda dealer and request these items? I haven't found a stockist that ships to Au
