I want to install a double din dvd player into my car so if I were to install the ek9 centre console to my 96 ek4, would everything plug and play? or do i need to change anything.
Cheers!
Cheers!
you need complete loom. and all plastic behind the dash. some parts will not fit
for aircon, but if u dont want aircon then easy
but to replace that center you need to take off the dash anyways
There is a very detailed writeup on hondatech. http://honda-tech.com/showpost.php?p...&postcount=323 it's for left-hand drive but you get the idea. everything is just swapped around.
You need alot more than just the double-din climate control. If you want to have a full functioning climate control, you'll need full 99+ climate & heater core loom, full heater core, full blower box and also need to get the centre vents re-routed into the 99+ ones as the centre vents are shifted to the left in comparision to the single-din.
alot more time consuming and expensive mod in comparison to what it's worth imo.. gl
Omg serious, **** that...cheers guys
I was thinking about this as well.. same thing for my EM1?
same thing for a em1 as well.
fekk... =='
was full excited!! maybe i shud just shove my fist through the centre console n just make the hole instead of doin the conversion.
