Attachment 17958
Any one have advice on how to remove this? Its harden steel and it takes like 2min to cut 1mm with an air saw. In case your wondering I have full cage with side intrusion bars so I have no need for this bar.
Thanks
Attachment 17958
Thanks
sounds about right... unless you use some sort of laser cutting device...
i think you posted the wrong picture btw
ITs the correct picture, its the wide plate in the door that I would like to remove
dude thats barely a bar.
umm one method i see people use is a die grinder, but with a cutting disc on the end. should work most efficiently
http://www.rv7blog.com/images/20070428_cutoff_tool.jpg
It doesnt look like much but its seriously heavy. Angle grinder is always an option but there's a high chance I might go right through the skin of the door as its so close! thanks anyways
Pretty sure it's also spot glued to the door skin as well to prevent rattles (apart from strength). I can see you're trying to reduce as much weight as possible but is the risk to the skin worth it?
Well pulled out the angle grinder and here are the results.
Attachment 17964
Attachment 17965
It was actually pretty easy with the grinder, just had to be careful not to cut the leavers for the door mechanism.
From full trim to what it is now I have saved easily 11kg per door, well worth the effort
Congrats! Thought the glue might have been more of a problem but looks like it wasn't holding on by much. Bet the heart was beating a bit faster when you were cutting through the bits close to the skin though.
Now that I've taken another look at the bottom pic I can see that whoever put the glue strips on didn't even get it in the right place!
the glue isnt a problem, trade specialists cut that glue like butter.
and with the grinder, you need patience with it.
atleast the job is half done now.hahah
Attachment 17997
door is almost complete :)
thats quite cool.
awesome work with the doors mate :thumbsup:
I am about to attempt a similar thing, although I only have half cage so have to keep the intrusion bars, still gonna cut most of the front skin out though. Was just curious, what windows will you be using? Poly? If so where are you getting them done? I have been trying to find a place in VIC for a while, but no luck yet.
