Hi all,
Anyone know if crx delsol seats bolt onto dc2 integra?
Or does it need modifying? What needs to be done?
Hi all,
I'm not sure, they might be direct bolt-in. Compare them and check.
If they are not, you have to make custom rails if you are really keen.
If I were you, I would buy DC2 Type R Sr3 Recaros. +they have good resale value if taken care of
I think crx del sol are based on the ek seating points. Otherwise eg.
Best thing to do is try a mates ek, eg, dc oem seats and see if it lines up!
Perfect. Sisters got an EK. So ill try a swap tmw.
I got a feeling it's not going to line up....
delsol seats fit directly onto the dc2. like, direct bolt on. this is because the delsol chassis is basically an eg chassis and the dc2 is basically an elongated eg. i had delsol seats in my eg and then dc2r seats, both of which fitted perfectly
Delsol into ek, you will need to change the inner rail on the crx seats with the inner rails on the ek seats (which isnt a terrifyingly hard job), then you can fit them onto the ek. or else they wont be direct bolt on
