Hi,
My gearbox shifting has seized up hard over the past couple of days. Now it's to the point where you have to be a bodybuilder to shift each gear. Neutral is ridiculously hard to find and it's really hard to slot into gear resulting in grinding sometimes.
I've just changed the transmission fluid and adjusted the clutch higher also. Hasn't helped with the issue at all. I'm suspecting it's the gearbox itself... what do you guys reckon?
