Originally Posted by TODA AU
Honestly 27% is a little bit optimistic.
Having fit both Motecs & aftermarket exhaust systems to S2K's,
I can tell you honestly that the exhaust alone is really only worth 5~6hp at the wheels... (Not that incredible)
Plus the real gain is only across the top-end of the revs.
There are gains to be had with the Motec, but mainly in the mid-range & low end.
Best results come from I/H/E + a cam change.
Unfortunately this car doesn't lend its self to many performance parts that are cheap & actually work.
The best bang for your bucks’ modification is a lightweight flywheel.
If you're interested,
The performance parts currently available from TODA Racing to suit the S2000 include the following...
2.2L stroker kits – Pistons, rods & crank. (For both NA & Turbo)
Spec A2 & Spec B Vtec killer camshafts, up-rated valve springs, vernier adjustable cam sprockets, Sports injection kit, Toda header etc...
Competition headwork is also available on request...
