as above...:D
as above...:D
What is an ITC? Which MSD model are we talking about?
The MSD SCI injection... as in can it be used to TIME ignition. Or can it only be used to create a "fatter" more consistent spark
The SCI is really just a 6A box painted silver instead of red (with a higher price tag of course). It has no control over timing, it just increases the power of the spark and outputs multiple sparks under 3krpm the same as the 6A does.
wot and where can i get a 6a?
Anywhere you can buy the SCI? They are on ebay for $150USD anyhow. Or look up the local MSD dealer. For more info on what it does, have a look on the MSD website and you can download the user manual. It basically replaces the stock ignitor module. You may use it with the stock coil, or else run an external coil. There are honda wiring diagrams in the user manual :cool:Quote:
Originally Posted by **Ghost**
do they actually wokr? as in any improvements?
Not really on a stock motor. The improvments will only start to show when you are running high compression, turbo, or alchohol fuel. The stock ignition system is powerfull enough for the stock motor.Quote:
