hey guys.
are these ebay short shifters any good? would be for a '90 ED 5spd
http://www.ebay.com.au/itm/HONDA-CIV...ht_3168wt_1165
hey guys.
$43 from Malaysia. I wouldn't be counting on it.
realisticly not many enjoy day to day use of a short shifter, they tend to make gear changes more clunky and shifting becomes more difficult as they theororetical gains by reduced throw are lost by needing to put more force into the change because of the shorter fulcrum and there for loss of mechanical advantage.
i know exactly what you mean. ordinarily i wouldnt consider something so nasty but theres not much to go wrong with something so simple.
i shouldve mentioned, im going to get a taller shift knob (mugen) and maybe a shift extension (2"?).
plus its 5mins work to change.
Avoid the aluminium ones. They snap.
Short shifts are fine for day to day use.
Simply adding a taller shift kknob / extension without a short shift will elongate the throw
...i realise that
are these short shifter simply just shorten the gear stick like the picture below?
http://i1168.photobucket.com/albums/...1/IMG_3772.jpg
if the distance between the ball joint to the bottom is the same, the short shifter only shorten the throw by reducing the length of the stick, and you gonna add a 2" extender will defend the purpose.
get a proper short shifter which lengthen the distance between the ball joint to the bottom where the gear linkage attach to
thanks but im asking about a product not the philosophy behind short shifters
i understand how and why a short throw shifter would and wouldnt work. just asking about cheap ebay ones because i feel the honda community is synonimous with cheap/nasty.
otherwise the skunk2 one looks good but is 3x the price.
i was planning to buy for my eg from ebay..someone selling for $15..thankgod i drove an ek with a short shifter..i won't go for it any more..
as long as its steel and not alloy as stated above then will be fine
only problem that sometimes occurs is due to being longer from the pivot ball,sometimes they hit the exhaust heatshield below and rattle
someone correct me i im wrong, but i read somewhere they can stuff up your synchros? purely because it effects the way the gears engage.. not necassarily an ebay one, but short shifters in general?
that being said, i have one in my pulsar and its probably the best mod ive done (besides a t28 :P) it gives the car a nice raw, sporty feeling!
