Checkerdsports Products ( Authorised Dealer ) *JDMyard*
http://www.checkerdsports.com/images...1kq%20copy.png
We are Checkerdsports official dealer
All Checkerd Sports Products are made in USA
http://www.checkerdsports.com/csproducts/oilcaps.jpg
http://www.checkerdsports.com/csproducts/oilcaps2.jpg
Oil Caps
-Made out of 6061-T6 Aluminum.
-CNC Machined
-Knurled outside for easy grip.
-Hand Polished, then Anodized for final Finish
-Available in Black or Blue.
-Applications: All Honda Engines
$75 incl GST
http://www.checkerdsports.com/csproducts/s2kspacer.jpg
http://www.checkerdsports.com/csprod...ercylinder.jpg
S2000 Clutch Master Cylinder/Spacer
This Spacer is used for direct bolt on. No need to cut/re-thread to your Master Cylinder
Made out of 6061-T6 Aluminum, then tumbled for clean finish.
IMPORTANT : Make sure to adjust the cmc rod so it is
fully at rest when pedal is also at rest. Every car is different and
might need small adjustment. Not checking can cause slipping of clutch.
1992-2000 Civic
1994-2001 Integra
$50 incl GST ( Spacer only )
http://www.checkerdsports.com/csproducts/egdcbossv2.jpg
http://www.checkerdsports.com/csprod...dcbossv2.2.jpg
http://www.checkerdsports.com/csproducts/boss5.jpg
RACE N1 STEERING BOSS Kit
Machined from billet Aluminum, Hand Polished.
Measures almost 5" long for closer position to driver.
•Checkerd Sports steering boss is designed for race purpose only! It replaces the original
SRS airbag steering wheel. The SRS airbag, cruise control, and horn button will no longer
operate. This is not a collapseable design.
•Designed for use with most aftermarket steering wheels with 6 bolt hole pattern
(Mugen, Momo, Personal, Nardi Etc..)
$265 incl GST (Available for EG/DC2 , EF/DA , EK/DC5/EP3/S2000/GD and GE Jazz *Air bag bypass wiring kit is not incl on the kit)
http://www.checkerdsports.com/csprod...hiftknobs2.jpg
Shift Knobs
Pick your preference of material, from lightweight duracon to weighted Stainless.
Checkerd Knobs measure 1.5" in diameter with Stainless and Duracon
at a 3.5" height and Aluminum at 3" height.
•Stainless Steel $110 incl GST
Weighing in at 624 Grams,Machine Spun Finish/ Lightly polished.
•Aluminum $70 incl GST
Made out of 6061-T6 ,Machine Spun Finish/ Lightly polished,Weighing in at 225 grams
•Black Anodized Aluminum $80 incl GST
Same specs just anodized black
•Duracon $80 incl GST
Machine Spun Finish , Lightweight 93.6 Grams
Applications:
10x1.5 mm Pitch Thread for Honda/Acura vehicles
More parts will be added soon
If anyone interested with other Checkerdsports Products , please PM or Email us.
