so im pretty sure im in need for a new clutch. it makes a sort of "zzzzzzzz" noise when ever i reverse or take off in 1st gear but only when gearbox is cold. aswell as not matching power with revs. and another point is that my friction point is pretty high, just near the pedal clutch play. so my questions are:
1) in the exedy website, it states that for my car i must check the bearing first. i expect they are talking about the release bearing, why would this be an issue? here is the link to the website>> http://www.exedy.com.au/SpecSheet.as...eetRowId=16546
2) while the gearbox is out, is there anything else that would be advised on replacing? and im right to re-use the pressure plate and flywheel right, it can be machined if its not worn too much?
help apprecaited:thumbsup:
