How do people sort out their short stock O2 leads when changing to aftermarket headers? Someone mentioned O2 extension leads but did not know where in AUS to get this.
Thanks!
Thanks!
yes there is but aint sure were to get them, you can take ur o2sensor to ur local auto electrician and they should be able to make u an extension with the same waterproof plugs, shouldnt be much more then $20 those plugs are at least $5-6 each.
Goodluck
just cut the wire and resolder some more wire in,
use heat shrink and then put it in conduit
ecu-man. i second that as that is wat i did...if ur lazy (like me) just rap it in electrical tape!
