hi guys, would a Rear Lower tie bar for EK/EJ/EM fit a del sol?
thanks
thanks
i think not...but u can use rear lower tie bars made for EG/DC for del sol...
most tie bars have slight adjustments in the ends. If you have this then yes it will fit.
The is a very slight difference in the length otherwise
is it also called a lower arm bar? what other names are there for this item?
Dude, do u have an EK tie bar?
Ive got a EG one when I need an EK
so it appears the rear subframe on ek and different to the eg/dc so the rear tie bars shouldn't fit
but anyone happen to know whether the front lower tie bars will fit between eg/dc/ek?
I bought SPoon tie bars from a guy here who drives an eg ans swear that they would fit the EK. Found out the rear tie bar for an EG is about 5-6cm longer than that for an EK, seems like the EK has longer LCAs.
The front ones on the other hand fits perfectly, therefore I guess yes it does fit between eg/dc/ek
interesting, time to find that front tie bar :D
