DIY REQUEST - Slave cylinder check
Im after a diy to take slave piston apart (that pushes the release bearing fork onto the pressure plate) so that im able to re- lube it. This can be done by taking off the slave cylinder, but not sure how to do that either.
Wanting to do this because of a noise when the clutch is out, and could solve the issue, as previously had the same noise in my delsol, and changed the isb and thrust bearing and did nothing.
ben has told me what to do, but im not good without any pics.
thanks.
any help appreciated.
