95 accord engine problems
hi all...
i am have some major problems with my 95 accord exi non-vtec...
it all started with a oil filter leak which was fixed by replacing the oil filter...
My current problem is when i am driving and i step on the accelerator (even a little bit) the engine (or car) shudders (it is jolting my body back an forth in the seat), very rough acceleration not smooth at all...could it be the timing belt?, it only has 50k KMs on the timing belt.i have never changed the spark plugs either, but the mechanic told me the spark plugs were fine...he also checked the distributor cap and rotor
the problem only exists when the car i warm and up to running temperature, when it is cool there seems to be no problem...it does it in every gear as well
it cant be the clutch slipping as i had a new clutch put in 9k KMs ago..and the revs dont just when it happens,
