hey guys changing my wheels on my eg its got 17s..changing it to some 14s for now..my question is will i need a wheel alighnment evertime i change my set of wheels..thank you
This link might answer your question...
http://www.ozhonda.com/forum/showthread.php?t=75173
wouldnt be a bad idea. how was the tread wear on the 17s when you took them off?
camber wear was bad..but i just got a wheel alighnmet about 2weeks ago..so just wondering if i have to get it again
i'd get your own setting eg. 0 toe front 1mm total rear. i don't trust the books tolerances. to much difference in it. if you had an alignment like this than another wont be needed until you hit a hard pothole, gutter etc but that is just normal then. there should be no difference in geometry by bolting a differnt wheel to the hub.
