Originally Posted by
omgzilla
There can be a few things that stop the A/C compressor from engaging such as too much gas, too little gas, clutch on compressor faulty, evaporator temp sensor faulty... the list goes on.
But seeing as the switch isn't lighting up it may indicate a power fault. Either at the climate control unit itself or somewhere along the circuit - before the climate control unit.
You can check power and earthing at the plug connection at the a/c compressor plug. If there is no power there, work your way back (checking power) along the wiring loom. Check at the relay/fuses. If everything else is in order, you may be up for a climate control unit.
