DIY GruppeM / K&N Air Filter Maintenance
Aim: Cleaning GruppeM / K&N Filters
Required: K&N Filter kit
Steps:
STEP 1. Remove the filter from the vehicle cleaner case, and use a soft brush to get rid of large dirt particles.
http://gruppem.co.jp/images/Clean1.jpg
STEP 2. Spray liberal amounts of the filter washer fluid on the filter, and let stand for 30 minutes (adjust the length of time according to the degree of dirt build-up).
*Note : Do not use high-pressure washing, steam cleaning, or solvents such as part cleaners, or gasoline, as these may damage the main body of the filter.
http://gruppem.co.jp/images/Clean2.jpg
http://gruppem.co.jp/images/Clean3.jpg
STEP 3. Rinse the filter from the engine side to the outer side using a gentle stream of water (be sure to avoid strong water pressure). After that, shake off all the excess water and let it dry in the shade.
*Note : Do not attempt to accelerate drying with an air compressor or drier, as the main body of the filter may become damaged and unusable.
*Repeat steps 2 and 3 until all the dirt has been removed.
http://gruppem.co.jp/images/Clean4.jpg
http://gruppem.co.jp/images/Clean5.jpg
STEP 4. After it has dried, lightly spray the filter oil along the filter pleats from the outer side. Be careful not to apply too much oil as it will further penetrate and permeate the entire filter when left to sit for 5 minutes. If there still appear to be white spots after this time, lightly sprays those areas again.
If oil other than the special filter oil is used, such as ATF, engine oil, gasoline, light oil, or lubricating oil, it may result in damage to the filter or cause engine problems. Only the special filter oil can be used. Also do not use the filter under any circumstances if the oil has not been applied.
http://gruppem.co.jp/images/Clean6.jpg
http://gruppem.co.jp/images/Clean7.jpg
STEP 5. Replace the filter on the filter case and the job is complete.
If it is a Replacement part, wipe the inside of the cleaner case before replacing the filter.
http://gruppem.co.jp/images/Clean8.jpg
http://gruppem.co.jp/images/Clean9.jpg
Other comments : TAKEN FROM gruppem.co.jp
http://gruppem.co.jp/en/maintenance.html
