Hi guys, would like to know if the spoon calipers would fit a stock dc2r wheel with spacers thanks...... really need help........ :D
stockies..? im assuming you mean the DC2R 15inch rims..?? if so... then im pretty sure it won't... those calipers are FAT!
Spacers may help clear it width wise.. but dia wise no..
Quote:
Originally Posted by OB
shit...... are you positive? cos i saw a civic type r with stock 15 inch using it in singapore with spacers
confirmed that it will fit with 3mm spacers on stockies.... cheers guys :DQuote:
Originally Posted by monstaR
with stock DC2R rotors... for some reason i thought u were going bigger rotors too...!?!? :confused:
yep correct... my bad... !!
u may like to check this out pal......
http://www.ozhonda.com/forum/showthread.php?t=9867
Cheers
I support monstaR, you need 3mm spacer to fit.......
haha you will have 1mm clearance after that haha
