hey peeps
turns out i got an eg half but it seems to have a b16 from a ef9 or sumfin
so its got an obd0 ecu customised to fit an eg
so everything has been wired to fit into the eg and was in running gear
should everything fit straight into my car ?
hey peeps
yes and no, tell us more about your civic, what year , what engine is in it currently, also more importantly what colour are your connectors for your distributor, cream or grey ? is your civic PGMFi ?
my current civic is a eg gli so its already an efi
in the half cut its got cream and grey connectors
ok but what colour is
the distributor connectors on the half cut
and what colour connectors on distributor of your EG
if your eg has grey connectors, and your halfcut has cream connectors, there will be some work involved. also is your eg hydraulic clutch and what is the half cut. cable / hydraulic ??
in my eg the connections are grey
in my half cut there are grey and cream connections
and in the half cut it was a cable clutch but has been modified to a hydro
if i can source out some obd1 looms is it possible tp rewier everything up to the obd0 ecu ?
yeah anything is posible, If your got the know how you can run the thing on OBD1, but since you got the ecu, you need to have it wired to your OBD0 ecu, you got all the parts all you need is the time, skills and pactiance to do the Job. good luck
hey thankz ecu-man
so if i can get sum obd1 looms would it be easy to wire it up to the odb0 ecu ?
hey btw can u hook me up wit sum wiring diagrams ?
for odb1 and obd0
and if you dont mind can i grab a contact number so i can talk to u properly and explain my situation ? btw im from melb
cheers
check your PM
