Spring install
hey ,
not a honda sigh
but im having a lot of trouble changing springs in an AU falcon lolz ,
i know its possible ozhonda has helped me change a clutch when i didn't even know how to change a flat tyre
heres what ive done so far , removed the top bolts left the screws hand tight , undid the bottom bolt and got spring compressors on the spring but how ? , what way do i use them??
http://img26.imageshack.us/img26/9167/dscf0238c.th.jpg
it seems like quite a simple procedure once i can get the shock and spring combo out hopefully someone can please pretty please shed some light
aww plz help
got the lower bottom nut of
i cant seem to slip it out from the top , cant get the spring compressors in
read a DIY of this forum , looks simple but dam it
you ned to remove the shock out of the mounting...THEN remove the springs.
there has to be a way the shock is removed - check the top for 2-5 locking nuts ontop.
yeap done them on the top under the hood , there all undone finger tight , but it looks as if the bottom of the shock is catching grip on the "lower control" arm or something
the bottom bolt has been taken out completely now
im stressing to much sigh
i feel safe now with bennjamin the king of DIY suspension
You have to get someone to help you push the hub down, while you remove the shock from the car.
but make sure the springs still captured...
sounds like he's undone the blots to remove the spring.. dont want to push down on the hub, release the shock and a spring comes flying off
yeap ,
been told by a fellow ford owner which has done EF falcon
i need to disconnect the upper wish bone which connects to the stub axle ,
sigh im lost, ive tryed pushing down on the hub but no luck
all ive undone is the top bolts , and the bottom which holds the shock in place
im crying my eyes out atm literally am crying
i want to put it back together i give up , its only a bogan mobile why bother
now the top of the shock thread , i kinda stripped it , hit it with a hammer on the top , now the bolt wont come of and its under the top "bump" stop
and the bottom shock bolt hole wont line up
all ive undone is the top bolts and the 1 bottom bolt ,
any advice would be appreciated
dude, its a really simple procedure. logic, look at what bolts need to be undone.
or if i were you, call a mobile mechanic. get them to put it back together and then u can pay someone to complete the job for you.
Go into the DIY sub forum, look for a spring shock thread made my me. I.e. search by user.
Also, i would advise against using any sorts of hammers.
Just jostle the shock around , look at where it may be stuck and then move it aorund so it becomes unstuck. it should pop back into place.
figured it out , paying a mate slab of bundy
we did 1 wheel today w00
quite simple just fiddly
cheers for the help
