White Smoke
hey,
i noticed as i was cumin home fromw ork tonight white smoke coming out my exzauhst and water coming out it as well droplets of water...
i drove it previously that day and there was no smoke.. it was only after i worked for 4 hours hoped in drove liek 3 kms home and noticed the smoek when i was shutting the gate...
i thought it might be water in the petrol, bad quality petrol???
do u guys know what thsi could be??? thanks.
Either condensation in your exhaust... but if it doesn't go after a few minutes, it looks like you might need to get the head leveled and a new head gasket. White smoke usually = coolant getting into the cylinders. Get a mechanic to do a gas leakdown test on your radiator - it will detect cylinder by-products that indicate a leaky head gasket.
yeah, it's most probably just condensation in the exhaust system. did you notice it when it was a cold night?
Just see if you get the same thing on long drives, if so then there may be a problem.
yeh it is cold tonight much colder than usual.. thanks for the help guys i will chek if its doing it in the morning....
-Liam
