Integra Vtir Vibration (Drive Shaft???)
Hey guys,
I had a problem about 3 months ago, were the drivers side wheel felt like it was wobbling side to side, took it to my mech. and we ended up having to change the drive shaft, that solved the problem, but my mech said that they couldn't really find a problem with the old shaft, but the new shaft had solved the problem. Today i did push it in 1st (not redline or anything) but all of a sudden that same wobble has come back. Is it just bad-luck that its happened again or is it something else??
What happens is
The whole car vibrates, the driver side wheel feels like its wobbling side to side, which gets worse as you speed up. When i come to a stop the wobble slows down and i can feel a knocking/vibration through the wall behind the pedals as if something is bent or out of place, also the shifter shakes side to side and gets worse as u go from about 3rd onwards. :confused:
