Originally Posted by LUD02C
Check your sunroof rubbers and rear window.
Also i got my Audison wet from were the water runs down the boot seal and under the car...
Check that the plug on the boot chassis is not filled up with dirt etc.
Also if your rubber seals on your window and sunroof is ok then check the tubes from the sunroof...
What i mean is where your aerial and that is there is a 2 inch tube (for excess water from the sunroof) alot of the time they never get cleaned and it fills up and guess what you have a puddle in your car. Both sides of the boot have this.
You have to un-do your boot trim to get to it and wiggle it through some medal (the chassis) and clean it with hot water.
Any questions, let me know.
