hey hey
mates got a spare d16y4 for me to use - doesnt have a dizzy tho.
can i use a EG d15b7 on it and simply rewire the dizzy wires to the correct pins ?
thankswill
hey hey
thankswill
If its going into an EK1, no you can only use Y4 dizzy cause it has extra sensors, wires..
I recon you can use a D16Y1 dizzy
you have to use a SOHC VTEC dizzy, D15B wont fit.
OP - it all depends what the motor is being used with ecu wise. The Y4 dizzy has extra sensors & OBD1 dizzy are different. thats why you have to change dizzies in an EK1 (Y4 equipped) if you want to run an OBD1 ecu...
ECU-man - would he get a CEL if he used a Y1 dizzy with stock Y4 ecu?
I guess it all comes down to what ECU he is going to use and what car it goes in. If he wants to run the D16Y4 ECU he has to use the Y4 dizzy
you cant run the Y4 Dizzy with an OBDI ecu
