hay guys just wanted to no if anyone has done a b16a head on to a b18c2 bottom end??? need help were to start and if anyone had any problems ???
Many many ppl have done if and there are many threads on it, for starters why do u wanna go this way? Do you think it will flow better because it is the same cast as the type-r head when in actual fact it IS the same but does NOT have the mild hand port job from honda resulting in an almost exact flow/output as a full stock b18c? Also doing this will lower ur compression ratio by about 2 points. The negative is, if you wanna go b16 head on a b18 u will have to spend more money to get a new head gasket and head studs/bolts instead of an untouched full b18c all for "no gain"
Thanks
Here we go, found it
http://www.team-integra.net/misc/ima...rheadstock.jpg
you would be better off looking into paring up the b16 vtec head with a b20 bottom, otherwise a straight b18c7 swap is easier, hassle free, cost effective.
thanks heaps guys :) can you guys point me in the right way to fine these forums
Where are u located man? wat car/motor and have u got anything yet?
ef3 civic b16a motor and b18c motor
its out now
trying to do the conversion
and have you seen or heard anyone put a turbo to this set up
ok cool so everything already setup for a b-series vtec, so why not just drop in the b18c, dont worry bout b18c with b16a head. have u got the b18c ecu also? would you consider going b20 block?
oh wait, was the b16a already installed?
no ef was an si and I already have the two motor so im just gonna go with that
